Andy_B
| posted on 15/5/11 at 09:52 PM |
Banjo for fuel pump
Evening...i now have my new fuel pump but it requires a 12mm banjo fitting with a 10 mm hose outlet to match my 10mm copper feed pipes...i can find an
8mm outlet but not 10mm ...its a sytec pump going on a 2.0 injection DOHC...if anybody has any ideas please reply...not far away from a first
start...(i hope) !!
jimgiblett
| posted on 15/5/11 at 10:22 PM |
If you drop in at your local Pirtek or other hydraulics place they should be able to sort for you. This is the size I have on my Bosch 044 pump
IIRC.
- Jim
MakeEverything
| posted on 15/5/11 at 10:45 PM |
12MM BANJO FOR 8MM HOSE M12x1.5 BOLT FUEL OIL | eBay UK
Kindest Regards,
Richard.
| posted on 16/5/11 at 01:08 PM |
Think the original post said he could find an 8mm outlet but not a 10mm which is what he is after.
Have a word with your local hydraulics suppliers or have a look at the Rally Design website, they do some reusable fittings which may be of use
Andy_B
| posted on 16/5/11 at 09:18 PM |
Thanks i have tracked down my Local Pirtek ....will drop my employers name and see if i can get a wee discount ...or i may just get shown the door
