Megasquirt II, EDIS and JimStim
I have my MS2 with extra firmware (V3 board) running with Tuner Studio and I'm trying to use EDIS.
With the JimStim connected I get rpm and everything works as it should, but If I jumper pin 36 output of the MS (SAW signal to the EDIS module) to one
of the LEDs in the stim, it stays always on.
If I jumper Tach (pin 24) to one of the LEDs it works and I can see it flashing at low rpm, but I think I should see the LED flashing when I jumper to
pin 36 in the MS.
Any help would be very appreciated!!
