Author: Subject: Where to have mapped
beaver34
posted on 27/6/11 at 07:14 PM Reply With Quote
I have a friend fitting a ej20 subarea lump in a t25 vw camper, he has ended up putting it on microsquirt, where in Yorkshire would map it?
Also anyone had anything to do with microsquirt? I run omex in my car but ive not had a look at thus stuff
matt_gsxr
posted on 27/6/11 at 10:50 PM Reply With Quote
Microsquirt is just prepackaged version of megasquirt.
Designed partially for motorbikes (small and more waterproof), but can be used on anything.
He just needs somewhere that can do megasquirt.
BaileyPerformance
posted on 28/6/11 at 04:33 PM Reply With Quote
We can do it for you, fixed price £250, www.baileyperformance.co.uk but a bit of a drive from you.
Can offer any help you require to get you started FOC
Cheers Dale.
beaver34
posted on 28/6/11 at 05:07 PM Reply With Quote
Thanks for that, don't suppose you have any base maps for that engine to get it going? I'll have a word with him see what we can sort
BaileyPerformance
posted on 30/6/11 at 11:31 PM Reply With Quote
Sorry no i dont have any base maps, plus you must be careful with microsquirt, the ignition drivers are very weak (manual suggests you DONT use them to directly drive a coil) EDIS is the best option if the engine can be fitted with a 36-1 trigger or external ignition amps can be used. A microsquirt is not the same as a meqasquirt but does use the same code and mapping software.
