Author: Subject: Map - ST170 with ITB's and VVT using MS3V3.0/MS3X
hiwex
posted on 14/9/11 at 10:23 AM Reply With Quote
When I destroyed my crossflow, I decided to go the whole way and install an ST170 with GSX-R750 throttle bodies.
Because I want to use the VVT I bought a Megasquirt 3 V3.0 with the MS Extra card installed. All the installation is done, but I know nothing of the murky world of mapping and hope there is someone out there with a similar set-up that might be able to send me a map to get me going.
Mike
posted on 14/9/11 at 11:24 AM Reply With Quote
Sorry mate, i'm using an Omex ecu....
Phil at efiextra might be able to help you.
hiwex
posted on 14/9/11 at 12:01 PM Reply With Quote
Thanks Steve, I have tried to contact you through U2U as I stumbled across some of your threads and realise you have a similar setup. I have already spoken to Phil, but thanks anyway.
Miek
dunk3
posted on 14/9/11 at 12:09 PM Reply With Quote
Hi Mike , have you tried BaileyPerformance , very good with Megasquirt, give him a ring and he will be more than happy to talk to you about it , here is his number 07967222967.
hiwex
posted on 14/9/11 at 12:40 PM Reply With Quote
No, but I will.
Mike
BaileyPerformance
posted on 16/9/11 at 09:26 PM Reply With Quote
Originally posted by hiwex
No, but I will.
Mike
Sorry i keep missing your calls, did call you today, will call again tomorrow.
I have never done a ST170 but have done a Honda Type R in a grass car with VVT and VTEC, both driven from megasquirt with jenvey throttle bodies - worked well and is now a class leader.
Should be no problem to sort your car.
Cheers Dale, Bailey Performance 07967 222967
