lotusmadandy
| posted on 17/9/11 at 08:06 PM |
2.0 zetec megasquirt 1 v3 map
Hi all,
I know this has been asked about a hundred times but......
I am about to start fitting the megasquirt1 v3 to my indy and need a map to get
the engine running.Can anyone help me out with a decent map that i can load up please.
Lots more questions will surely follow.
Cheers peeps
[Edited on 17/9/11 by lotusmadandy]
lotusmadandy
| posted on 18/9/11 at 05:53 AM |
Anyone help please????
ashg
| posted on 18/9/11 at 06:14 AM |
the standard generic base map on the ms should get it running you just need to work out the required fuel settings. follow the ms manual and you
should be ok. i think there is a repository of maps on one of the ms sites but i cant remember the site, google will be your friend.
[Edited on 18/9/2011 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
lotusmadandy
| posted on 18/9/11 at 07:45 AM |
Thanks Ash,I didnt realise that the chip was already
loaded with a map to get the engine running.
BaileyPerformance
| posted on 18/9/11 at 09:21 AM |
quote: Originally posted by lotusmadandy
Hi all,
Cheers peeps
Hi, are you using stock (white) 2.0L injectors on totally stock engine?
Prob be able to make a base map for you, whats your email?
lotusmadandy
| posted on 18/9/11 at 09:38 AM |
Hi Dale,
Thanks for the help.Yes i am using stock 2.0 injectors
on a mostly stock engine(for now) .Although the inlets
have been opened out mildly.
u2u sent.
