t11
| posted on 19/9/11 at 05:52 AM |
Sencor's
Hi all can any one out there tell me what sencor's work with megasquirt part numbers would be helpful, I see ome of the web site's they
list the water and air temp sencor's as these will work but do you still have to set these up first.......thanks Gordon
matt_gsxr
| posted on 19/9/11 at 09:48 AM |
If you go with the appropriate GM sensors, then you don't need to set it up first.
http://www.megamanual.com/v22manual/mwire.htm
If you use other sensors then you do.
Have you got MS1 or the MS2 daughter card?
With MS1 you can use a program called Easytherm to calibrate everything.
With MS2 it is easier and you can just calibrate the sensors from TunerStudio.
