ChrisLeary
posted on 22/9/11 at 07:04 PM |
megasquirt fuel pump wiring
Evening all,
I've started stripping the 7 I bought a couple of months ago to tidy things up and sort things out. I've started to strip the wiring out
and I started with the engine loom. The car is running a 2.0l zetec silvertop with megasquirt 1 V3. I've managed to trace all of the cables to
sensors around the engine and disconnected them, I now have the engine side of the loom completely out of the car.
I'm a bit confused though. I've got a relay to the 12V+ supply to the ECU, which I've removed with the loom, but I'm confused
as to where and how the fuel pump is wired up? I've got a single cable coming from the 37pin MS plug, but I'm sure it was running to
another relay.
Can anyone help??? PLEASE!!!!
Thanks in advance,
Chris
r1_pete
| posted on 22/9/11 at 07:17 PM |
The diagram here should help Link
Pin 37 grounds and engergises the relay, on switch on, then only when the engine is running.
[Edited on 22/9/11 by r1_pete]
Rod Ends
| posted on 22/9/11 at 07:21 PM |
Megasquirt wiring diagram
ChrisLeary
| posted on 22/9/11 at 09:54 PM |
Ok I've had a read and looked at the wiring diagrams.
So literally all I need is a relay from ignition to the fuel pump with a live feed in and the single cable to the MS unit itself?
I bought the car with this system already installed, so please be gentle with me.
Thanks again.
Chris
ashg
| posted on 23/9/11 at 08:41 AM |
remember the fuel pump output on the ms is ground switching. basically you put a live to one side of the relay coil then the negative side of the
relay coil goes to the ms.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
