big-vee-twin
| posted on 28/9/11 at 08:25 AM |
Megasquirt/Microsquirt
Any one ever used a Microsquirt?
How does it compare to the Megasquirt?
Does the collective have an opinion on which is best?
Many thanks in advance
http://www.triangleltd.com
matt_gsxr
| posted on 28/9/11 at 09:16 AM |
its smaller.
What do you want to do with it.
big-vee-twin
| posted on 28/9/11 at 09:25 AM |
I want to run a Duratec with GSXR 750 throttle bodies nothing special
matt_gsxr
| posted on 28/9/11 at 12:44 PM |
http://www.ms3efi.com/feature-xref.html
megasquirt2 is the version of megasquirt that is most similar to microsquirt.
Microsquirt has fewer outputs and isn't bodgeable, but is more nicely packaged and is ideal for motorcycles.
You need to check that the things that microsquirt doesn't do are not things that you need. For example idle control, tacho output, nitrous
control. But if it does everything that you need then it is neater.
MikeR
| posted on 28/9/11 at 01:24 PM |
IrvineD has microsquirt on his locost (i think). Upgraded from a megajolt and has done a good few miles.
matt_gsxr
| posted on 28/9/11 at 02:30 PM |
FlakMonkey had ms2 on his duratec.
Probably worth asking.
