posted on 19/10/11 at 07:11 PM |
Velocity Stacks & Gauze
Still mulling over what to do for an air-feed for the trike.
What do the masses think of running these stacks with gauze only? I normally wouldn't entertain it, but the BMW boxer-engines TB's point
towards the back of the vehicle so are less likely to come into contact with grit and other crud (that's the theory anyway! ).
It's Evolution Baby!
franky
posted on 19/10/11 at 07:19 PM |
what i'd do it cut some foam and put it inside the stacks. Then it looks cool but still stops it sucking in crap.
Confused but excited.
But then there's the effect of vortices to consider.
posted on 19/10/11 at 07:21 PM |
What stops it sucking in the foam?
Surely you would use the mesh to support the foam?
HowardB
they look good, where are they from?
Just a little bit of foam over the mesh might keep some of the sh1t out?
[Edited on 19/10/11 by HowardB]
Howard
posted on 19/10/11 at 07:27 PM |
Do explain...
posted on 19/10/11 at 07:28 PM |
quote: Originally posted by HowardB
they look good, where are they from?...
Dellorto PHM trumpet + gauze 45mm Guzzi BMW Ducati | eBay
posted on 19/10/11 at 07:40 PM |
Do explain...
Was said tongue in cheek.
As you move forward you create vortices which swirl around the back of the vehicle.
Look at all the crap on the back of a van. Wheels throw it up in the air and air movement swirls it all around the back.
posted on 19/10/11 at 07:52 PM |
That makes sense!
clairetoo
posted on 19/10/11 at 07:55 PM |
All I would say on these is - NO WAY !
One thing no one seems to realize about that gauze - it cuts the area of the inlet down by as much as half , and while it will stop small children
getting sucked into the engine , it will also stop a lot of air getting in as well - and that will cost you horsepower .
Its cuz I is blond , innit
Claire xx
Will weld for food......
posted on 19/10/11 at 08:01 PM |
Cheers Claire! Decision made!
posted on 19/10/11 at 08:16 PM |
Good decision.
These things are OK to keep gravel out of a race engine, which will be re-built after one or two races but all the road dust that they let in, will
wreck a road car engine in very short order, relatively speaking.
posted on 19/10/11 at 08:18 PM |
... and that's just made up Howards mind too! You're not getting any!
posted on 19/10/11 at 08:19 PM |
posted on 19/10/11 at 11:19 PM |
It will keep most of the air out as well.
bi22le
posted on 20/10/11 at 07:31 AM |
I had a knightmare with this and am currently running with cut up womens tights!!!
I cleaned inside the TBs before and there seems tobe no gunk at the mo.
i did try zip ties and foam but it really choked the engine.
Please read my ring story:
HowardB
posted on 20/10/11 at 07:36 AM |
thanks for that, very sweet,... but essentially useless,.....
[Edited on 20/10/11 by HowardB]
Howard
40inches
posted on 20/10/11 at 07:41 AM |
There was a feature in PPC by Dave Walker, in that trumpets with the gauze dropped power by as much as 25% I think it was a Jag
engine he was setting up that lost 50 BHP with them fitted.
posted on 20/10/11 at 10:36 AM |
Unless you mean you are out for a jog wearing hosiery which is past it's best, then you are strangling your engine.
franky
posted on 20/10/11 at 11:39 AM |
maybe you could do a few dyno runs just to see how it does affect it. If you only loose 2-3bhp but it gives you the look you're after then
maybe you could use them.
The best way would be to use the standard airbox but i bet it looks like a plastic titanic
sprouts-car
posted on 20/10/11 at 11:51 AM |
Wouldn't this be cheaper?
Build blog
posted on 20/10/11 at 06:48 PM |
The standard HP2 airbox looks like a Dalek (and wouldn't fit into my frame anyway)!
What about those 'cone' type filters made by the likes of K&N and Pipercross going straight on the TB?
franky
posted on 20/10/11 at 06:59 PM |
I use to use them on 2 stroke bikes in my yoof
to be honest i'd look at some sort of airbox design, even if you just match the volume and size/shape near the inlet. Bike engines are so so
sensitive to airbox's. I'd put 28.3p on all the BEC cars that run really well on here have standard airbox's.
posted on 20/10/11 at 07:10 PM |
28.3p ... I can tell you're confident!
40inches
posted on 21/10/11 at 07:28 AM |
How about something like this. Link
