samjc
| posted on 27/10/11 at 09:38 PM |
This may help stop fuel troubles when cornering.
Ok not sure if this is in the right place, well I was looking for odd bits and have seen this before but forgot but after noticing people saying about
issie with fuel tanks I thort id post this, I know its a bit pricey but givrs an idea for what to look for if you hsve issues with fuel sloshing
about in the tank.
http://www.demon-tweeks.co.uk/Motorsport/Fuel_System/Fuel_Tank_Baffles/Demon_Tweeks_Easy_Pour_Fuel_Tank_Baffle_/1545/0/23019
coyoteboy
| posted on 27/10/11 at 10:06 PM |
Bit like ....
http://merlinmotorsport.co.uk/product_info.php?products_id=1055%20&utm_source=Google&utm_medium=ShoppingUK&utm_campaign=ShoppingUK ?
stevegough
| posted on 28/10/11 at 06:21 AM |
Neither are any use if your fuel gauge sender uses the standard float arm.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
liam.mccaffrey
| posted on 28/10/11 at 06:45 AM |
sorry am I missing something here, aluminium spheres for £40, They look an awful lot like crumpled up tinfoil to me, on closer inspection looks more
like ball of rolled up swarf
It looks like they have their level sender in a still well on that pic,
[Edited on 28/10/11 by liam.mccaffrey]
Build Blog
Build Photo Album
samjc
| posted on 28/10/11 at 08:31 AM |
Was hope their were cheaper way and agreed look silly for the money, I thort for sender to be fitted in a tube with holes in so no interferance from
packing it may work with foam but not the balls.
rachaeljf
| posted on 28/10/11 at 09:31 AM |
How about this....?
http://www.thefactoryshops.co.uk/rp/products/DZT1009.htm
Cheers R
| posted on 28/10/11 at 09:32 AM |
quote: Originally posted by rachaeljf
How about this....?
Cheers R
It's Evolution Baby!
coyoteboy
| posted on 28/10/11 at 01:01 PM |
I actually know of a team competing with that as a solution. It works (if designed in correctly), don't knock it
rachaeljf
| posted on 28/10/11 at 01:19 PM |
Yes it wasn't entirely in jest! Just don't use the ones that come impregnated with soap.
loggyboy
| posted on 28/10/11 at 01:28 PM |
How about this....?
Cheers R
I would expect that by the time you have bought enough of them to do the equic 105 litres the £40 ones do, they will be more expensive!
Rod Ends
| posted on 28/10/11 at 04:15 PM |
Go direct to source
