scudderfish
posted on 5/11/11 at 12:55 PM |
MSLogger available on Android Market
It's finally available, after good feedback from my beta testers. The app is split into two versions, the first free "MSLogger Connection
Checker" https://market.android.com/details?id=uk.org.smithfamily.mslogger.vanilla makes sure that all the plumbing works between your Android
device and your Megasquirt ECU. If it works, you can then buy for the princely sum of £3 (of which I see £2, so think of it as buying me a pint) the
full MSLogger. Supported firmwares are listed at http://www.mslogger.co.uk/firmwares.html
Regards,
Dave
HowardB
posted on 5/11/11 at 01:09 PM |
looks great, is there min hardwear reqm? I'd hate to buy something Android only to find I couldn't then use it for something as fantastic
as this,...
Howard
Xtreme Kermit
posted on 5/11/11 at 01:41 PM |
Result!
A lot of hard work went into that. Well done
Paul (Notts)
posted on 5/11/11 at 01:46 PM |
Do I need some sort of bluetooth adapter for my MS?
Paul
matt_gsxr
posted on 5/11/11 at 01:53 PM |
Paul
Yes. Some information here. https://bitbucket.org/scudderfish/mslogger/wiki/Adapters
Basically will cost you about £30 and an hour or so messing around.
[Edited on 5/11/11 by matt_gsxr]
matt_gsxr
posted on 5/11/11 at 01:58 PM |
as this,...
I have a Orange San Fransisco (which was at the budget end of the market when I bought it a year ago), so I would suspect that anything newish should
be fine. Just note that you need a fairly recent version of Android, so if your phone is locked with an old version then this could be a problem.
Installing a new version of Android on my phone was trivial (and improved it in a lot of other ways too) but its worth checking.
The final product is really nicely implemented.
scudderfish
posted on 5/11/11 at 03:17 PM |
On the up side of buying an adapter, if your laptop has Bluetooth then you can also use the full TunerStudio with it as well.
Regards,
Dave
HowardB
posted on 5/11/11 at 03:19 PM |
wow, that will be great, and I will look out for something in the Jan sales,... don't imagine that I'll have anything ready before then at
the rate I'm proceeding,...
Howard
