FatChapChipChop
posted on 24/11/11 at 07:22 PM |
MX5 In-Tank FPR Question
Hi All;
I've just had a tank made, and have modified an MX5 in-tank Injection fuel pump assembly to fit in a vertical fashion using an uprated pump
dipping into a pot in the bottom of the tank. All seems good, quite happy with how it will work etc .. However, I have a question ..
The return pipe into the tank has a Fuel Pressure Regulator on it, also in the tank. I believe it's around 34psi rating. I'm not certain I
want this in the tank, so does anyone see an issue with me using an after-market regulator off the end of the fuel rail? .. with the return being
simply an "open return" with no restriction?
You can see the currentr assembly here with the attendant FPR :
Cheers !!
Drive fast, don't look back!
paulf
posted on 24/11/11 at 09:28 PM |
No that should be OK it is how most systems are set up , it will be better than having both supply and return lines running at full system
pressure.
Is that a bit of neoprene pipe insulation wrapped around the pump or is it OE fitment ?
Paul
FatChapChipChop
posted on 25/11/11 at 08:50 AM |
Thanks, I'll go fo an external FPR then ..
The foam was supplied with the pump. As it is sold as an in-tank pump I'm presuming it will be OK in fuel .. However, you mentioning it means
I'll be trimming a bit off to dunk in fuel to see if it stays in one piece ..
Cheers !!
