AntonUK
posted on 26/11/11 at 11:16 AM |
Megasquirt Ordering
DIYAutotune have another offer on this weekend so I want to get my megasquirt kit ordered up. Before I press the button to order I thought it might be
a good idea to run it past you guys and check that I am ordering the correct thing.
I will be running a 1800 silvertop zetec, on GSXR throttle bodies, and keeping the EDIS for limp home.
My Basket is the following:
MSII on a v3 board-
http://www.diyautotune.com/catalog/megasquirtii-programmable-efi-system-pcb30-kit-black-case-p-119.html
Stim-
http://www.diyautotune.com/catalog/megasquirt-stimulator-v22-unassembled-kit-p-30.html
Loom-
http://www.diyautotune.com/catalog/839-megasquirt-wiring-harness-ms1-ms2-ms3-ready-p-477.html
I have the RS232 cable from a previous mejajolt install.
Any comments, suggestions or criticisms welcome??
Ben_Copeland
posted on 26/11/11 at 03:14 PM |
If you have any doubts ask them when ordering, they are very helpful and will also make sure you get all the bits you need to match your engine.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
big-vee-twin
posted on 26/11/11 at 03:53 PM |
Just finished building mine wouldn't bother with the loom as a plug comes with the kit build your own and save some cash
http://www.triangleltd.com
lotusmadandy
posted on 26/11/11 at 05:10 PM |
same here. I didnt bother with the loom, i used the
plug that came with the kit and bought a fuse box and
a pair of relays.It was real easy to wire up and a fraction
of the cost.
AntonUK
posted on 26/11/11 at 06:24 PM |
I am in 2 minds to the loom tbh... I'm quite happy wiring up a connector but what I like about the DIYAutotune version is the printed text on
each wire.
AntonUK
posted on 26/11/11 at 06:56 PM |
ahhh.... http://www.diyautotune.com/catalog/megasquirt-wiring-bundle-1239-long-p-101.html
AntonUK
posted on 26/11/11 at 07:59 PM |
Cheers all...
Done... ordered and should be here in a week or so
[Edited on 26/11/11 by AntonUK]
lotusmadandy
posted on 26/11/11 at 08:35 PM |
Well done..Enjoy the build,i did.
I fitted it on the indy on thusday,switched on the ignition to prime
the fuel rail,then held my breath and pushed the starter button.
It started immediately putting a huge grin on my face
BaileyPerformance
posted on 2/12/11 at 10:22 PM |
MSII on a v3 board-
Stim-
Loom-
Any comments, suggestions or criticisms welcome?? [/quot
Hi, just one comment, lots of people say EDIS gives you limp home, this is not the case, if you loose the SAW signal from the MS to the EDIS then the
timing is fixed at 10deg. If the MS fails or the PIP signal is lost the engine will stop. Not really limp home. Having said that EDIS is still the way
to go if your using a 36-1 wheel. Nice and simple, no dwell settings to worry about.
Look out for a 2L lump if i was you, the extra torque is really noticeable.
AntonUK
posted on 2/12/11 at 11:25 PM |
the 1800 was a cheapo from ebay for mock up and testing / get the car running kinda thing.
In the future I want to run a 2l turbo lump
