Author: Subject: Megasquirt weirdness! Help please
adrianreeve
posted on 10/2/12 at 09:20 AM Reply With Quote
Ok, so thought I'd have another quick go at getting the car started. Until now, all is well, fuel pump does its thing for 3 secs, engine cranks over, few coughs and splutters, not quite there though. Up the req fuel a bit and try again. Suddenly as I'm cranking, the fan kicks in ( it's -2 in my garage!), and I lose comms to the ecu. Now if turn the ignition on, the fan comes on straight away. As I said, it was all wired up properly and working as it should, and I haven't changed any wiring. The car hasn't moved under its own steam yet, so I don't think anything could have shaken loose or moved.
Does anyone have any idea where I should start fault finding here? Megasquirt or wiring?
Anyone got an emerald or Omex they want to sell me?!
Any help much appreciated.
Adrian
MakeEverything
posted on 10/2/12 at 09:28 AM Reply With Quote
Is the fan wired to the ecu or a thermostatic switch?
Kindest Regards,
Richard.
adrianreeve
posted on 10/2/12 at 09:33 AM Reply With Quote
Through the ecu via a relay, wired as per the extraefi drawing.
Adrian
ashg
is the fan setup to be controlled by the ecu or is it a separate switch in the rad?
if its controlled by the ecu chances are you have just got a pin misconfigured in the software.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
adrianreeve
posted on 10/2/12 at 09:37 AM Reply With Quote
That's rhe weird thing ash, it wasn't doing it, and now it is! If it was a pin config problem, would have thought it would always have done it?
MakeEverything
posted on 10/2/12 at 09:39 AM Reply With Quote
Adrian
Depends what version you've got as to what drawing youre referring to! Mine is on a rad switch, not the ecu as per extra efi drawing.
Have you tried unplugging it all and plugging it back in again? Same as removing the 12v feed really. May be the relay pulled in throu a glitch in the software?
[Edited on 10-2-12 by MakeEverything]
Kindest Regards,
Richard.
scudderfish
posted on 10/2/12 at 10:07 AM Reply With Quote
Is the +12v side of the fan relay that the MS grounds connected to a perm feed? I originally had mine set up like that and when I plugged a BT module into my serial port the fan would switch on and the MS would do weird things as it pulled power through the floating 12v. With just a serial connection, the ECU would occasionally drop into boot mode when you tried to switch it off.
adrianreeve
I tried disconnecting the battery, but it still does it.
adrianreeve
posted on 10/2/12 at 10:09 AM Reply With Quote
Can't remember scudderfish, I'll have a look, cheers
rachaeljf
posted on 10/2/12 at 10:34 AM Reply With Quote
If you've lost comms the ecu has lost its mind. You might need to reflash it.
Cheers R
matt_gsxr
posted on 10/2/12 at 10:54 AM Reply With Quote
What temperature is it reading?
No need to give up yet, but if you do I am sure your MS will fetch good money.
posted on 10/2/12 at 11:21 AM Reply With Quote
I know it might seem too obvious but is the ECU earthed properly ?
adrianreeve
posted on 10/2/12 at 12:06 PM Reply With Quote
Pretty sure the earthing is ok. Any reason the ecu would lose its mind? All I've done is crank the engine over!
rachaeljf
posted on 10/2/12 at 12:13 PM Reply With Quote
It is unusual to scramble the processor, but it happens. I believe voltage spikes getting through to the cpu, often caused by the ignition, can do it. Are you using ignition drivers inside the MS case?
What software are you using? Is your MS a bought one or did you build it?
This could easily grow into a huge Q&A thread; it's probably best to search in the MS forums for answers!
scudderfish
posted on 10/2/12 at 12:28 PM Reply With Quote
My MS used to give the impression it was dead (unresponsive, TS wouldn't talk to it), but it was in boot mode. Power cycling didn't appear work because it was getting a feed through the fan relay.
In TS go to Comms menu, Mini Terminal, connect and press Return. If it responds with "Boot>?" (or something like that), press X and it should then be ready to go.
adrianreeve
posted on 10/2/12 at 02:01 PM Reply With Quote
Thanks for the advice guys.
It was built by Bill Shurvington originally for Flak Monkey on here, then freshened up by Phil at extra efi last year, so I'm confident of the build quality. It's running with coil drivers, no edis.
kemills1
posted on 24/2/12 at 09:32 PM Reply With Quote
MS
Hi.
if the fan is going at switch on, does the fan status indicator on the PC interface show the fan is activated? If not, maybe you have a stuck fan relay. Also back emf from relays can fry transistors. Does you MS have diode protection on the relay drivers?
Kev.
BTW, there should be a jumper fitted to go into boot mode. Is this fitted?
[Edited on 24/2/12 by kemills1]
Kev
