adrianreeve
| posted on 9/3/12 at 09:18 AM |
LC1 and omex 0v and 5v values needed please!
Hi there, having got the engine running, I'm now setting up the LC1 wideband controller. I spoke to omex, and they talked me through how to set
it up, but they didn't know what the 0v and 5v lambda values for the LC1 were. I had a quick look in the LC1 manual, and can't see the
info in there, so was wondering if any of you good folk had the info to hand?
Thanks very much
Adrian
rachaeljf
| posted on 9/3/12 at 12:47 PM |
From the LC1 manual, page 4 paragraph 6:
"Analog output two is setup as 0V = 7.35 AFR and 5V = 22.39 AFR."
This is your "wideband" output. Analogue output 1 simulates a narrowband sensor.
Cheers R
[Edited on 9/3/12 by rachaeljf]
matt_gsxr
| posted on 10/3/12 at 11:47 PM |
The manual is downloadable.
http://www.innovatemotorsports.com/support/manual/LC-1_Manual.pdf
There are some LC1 defaults (probably as described above).
Alternatively you can reprogram the LC1 to output different voltages, you need a serial port on your lappy (big pain) and the cable that takes serial
to that small headphone style connector. It is all described in the manual.
adrianreeve
| posted on 11/3/12 at 06:21 AM |
Thanks gents, all sorted now, couldn't see it in the manual for looking!
