Author: Subject: Fuel Injection copper pipe and hose setup.
karlak
posted on 19/3/12 at 06:32 PM Reply With Quote
Having been shown and told the possible error of my ways if I choose to have a Braided Hose for the full flow and return, what is the suggested way of connecting from the Copper pipe to the ITB's and Fuel tank.
I really would like to have braided fuel hose either end of my copper runs, but how do I connect the braided hose to the copper on a Fuel injection system with higher pressure.
Any pictures of anyones setup or link to suitable sites would be much appreciated
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
tilly819
posted on 19/3/12 at 07:40 PM Reply With Quote
double flair the end of the copper pipe like a brake pipe then put the hose on and jubalee clip, the flair will act like a bead does on a radiator pipe
tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
dave r
posted on 19/3/12 at 07:51 PM Reply With Quote
my pipe was hard to flare, so i have soft soldered olives from compression fittings on the end
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
posted on 19/3/12 at 08:59 PM Reply With Quote
Use a decent pipe flaring tool but do not use a double flare and then use proper fuel hose clips DO NOT use Jubilee clips as they are more likely to cause a leak.
tilly819
posted on 19/3/12 at 09:49 PM Reply With Quote
why not use a double flare, if you use a single then it leaves a sharp edge which will cut into the rubber and potently over time cause damage to the hose
tilly
owelly
posted on 19/3/12 at 09:58 PM Reply With Quote
There may be some confusion with terminology. As I understand, a double flare is a single flare (male) with the end pushed-in to make the end concave (female).
http://www.ppcmag.co.uk
zetec
posted on 19/3/12 at 10:25 PM Reply With Quote
I did the 8mm olive route soldered onto the pipe thing as did not have a flare tool, also used jubilee clips and no leaks for last 8 years and 10k miles...
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
Chippy
posted on 19/3/12 at 10:40 PM Reply With Quote
Ditto^^^. Ray
dave r
posted on 20/3/12 at 06:38 AM Reply With Quote
nothing wrong with my flaring tool,(snap on) it was jut the pipe that came from where i used to was very hard....
Oddified
posted on 20/3/12 at 09:14 AM Reply With Quote
Ditto^^^. Ray
Same here, simple and works perfectly
Ian
