Nitrogeno25
| posted on 29/3/12 at 10:14 PM |
Stainless fuel pipe
I found a supplier for stainless pipe in 3/8" (1mm wall) that I plan to use for my fuel lines. 6 meters at $10 sound cheap enough, I don't
know what it is use for. Is there any recommendation for using it?
I plan to flare the ends to fit fuel lines with hose clamps (efi)
Thanks!
owelly
| posted on 29/3/12 at 10:34 PM |
Flaring the ends may be a bit tricky as stainless is renowned for being a bit hard! I used a pipe-cutter to score grooves in the ends of my stainless
fuel pipes and used good quaility, correctly sized worm-drive clips and they've been fine.
http://www.ppcmag.co.uk
