Nitrogeno25
| posted on 25/4/12 at 11:57 PM |
Fuel tank sump
I'm building my tank and trying to decide how big the sump should be. (I don't plan to fit an in-tank pump, nor an external swirl pot)
What is the common size for a sump to work (road and track)?
Thanks!
blakep82
| posted on 26/4/12 at 10:46 AM |
there must be some sort of mathematical answer, but basically is needs to be big enough to collect fuel as it moves around the tank, but not let too
much back out on corners.
i am planning to get a sump added to mine, i'm thinking maybe 4" diameter, and about 1.5" deep, and a hole in the bottom of the tank
slightly smaller, maybe 3" diameter so it leaves a lip round the top of the sump to make it harder for fuel to get back out
don't know if theres any common size really
________________________
garybee
| posted on 27/4/12 at 12:53 PM |
Assuming you are running a fuel injection system...
Do you have a return to the tank? If not then you only need a sump/collector large enough to allow for what your engine uses during cornering. If you
are running a fuel return, then your collector needs to be big enough to allow for what your engine uses plus the amount returned from the fuel
pressure regulator to the tank (unless your return feeds back into the collector).
There is obviously a pretty large difference between these two figures so your type of fuel system is very important.
Nitrogeno25
| posted on 27/4/12 at 01:11 PM |
Yes, return to the tank, I think I can make it to feed the collector. Engine is 2.0 Duratec on Jenveys. Fuel pump is a Bosch external 130l/h
Thanks!!
adithorp
| posted on 27/4/12 at 01:12 PM |
The one on mine is cylindrical, approx 150mm diameter and 60mm deep so approx 1/2lt capacity. The hole between the main tank and the sump is about
75mm so gives a lip/baffle.The pick up is in the bottom and the return goesbackinto the sump. Never had the slightest stutter either on track or on
mountain hairpins... even when almost empty. My only fear is it's so good I won't get any warning untill it's dry and used every
last drop.
My previous tank (plastic) had a moulded sump with no lip/baffle, pick up in the side of the sump and the return into the main tank. It would stutter
when cornering hard with less than a 1/8tank.
http://jpsc.org.uk/forum/
Nitrogeno25
| posted on 27/4/12 at 09:19 PM |
last drop.
Thank you very much! This is what I need to know.
