t11
| posted on 19/6/12 at 06:12 AM |
ms 11 and stimulator
Morning all, I've been trying to get my stimulator working with my ms 11 but not a lot of luck most of the dial's on the dash work apart
from the rev gauge and none of the led's light up on the stimulator, I've seen a few demo's on youtube and as you rotate the rev pot
the rev gauge gauge goes up and the led's light to show that the injectors are working...any idear's people ?.....Gordon
Ben_Copeland
| posted on 19/6/12 at 06:31 AM |
Hi Gordon.
As I said last night I wouldn't worry about the revs too much because you have megastim not jimstim.
I did a search on msextra.
That stim cannot generate a 36-1 wheel pattern, so you won't be able to use it to test that.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
t11
| posted on 19/6/12 at 11:06 AM |
thanks Ben thought thats what you said........but just wanted to be sure...even tried a 12v power supply......
big-vee-twin
| posted on 19/6/12 at 04:02 PM |
You can go into the software and tell the MS to work from a set of points and it will then let you test it using the stimulator, obviously doing it
this way you are not testing the VR input but everything else can be tested.
This is how I tested mine, even though I built it to be a waisted spark with no EDIS system.
Once done dont forget to put the setting back to original
http://www.triangleltd.com
