Author: Subject: good new sensors for ms2
baz-R
posted on 24/6/12 at 11:49 PM Reply With Quote
anyone know what good new sensors are about sutable for a std build ms2 on v3 pcb
im after an air and coolent temp sensors and was hopeing there was somthing with a a conector you can get plugs for easy and is idealy oem based so can be cheaply and quickly got from any autofactors
Ben_Copeland
posted on 25/6/12 at 06:34 AM Reply With Quote
It's setup for GM sensors, but you can tune it for any sensor. Motorfactors will have the sensors but not connectors for them.
Phil @ extraefi has the sensors and pigtails.
[Edited on 25/6/12 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
big-vee-twin
posted on 25/6/12 at 09:23 AM Reply With Quote
Here's the MAT sensor I have used, I used the standard Ford water temp sensor Megasquirt manifold air temperature sensor + connector | eBay
http://www.triangleltd.com
