baz-R
| posted on 11/9/12 at 06:20 PM |
where to get plugs n sockets?
im looking for all the bits in the conector wise to do my megasquirt install and need plugs for pickup,injectors and so on
i would like to use new rather than my old stuff
i need 2 pin junior power timer plugs mostly and a good 3 pin sealed plug and socket for my tps
where is a good but nice and cheap place to get thease bits and bobs?
its common stuff and would be good if i can buy each indivule connector as a pack to makeup a complete unit to make life easyer
anyone?
r1_pete
| posted on 11/9/12 at 06:30 PM |
Vehicle Wiring Products should have all you need.
[Edited on 11/9/12 by r1_pete]
40inches
Vehicle Wiring Products?
Snap
[Edited on 11-9-12 by 40inches]
big_wasa
| posted on 11/9/12 at 06:32 PM |
Mini timers are easy (ebay) but new coil and tps are not. I think trigger wheels want 20 quid for the coil plug. You could just remove all the pins
and buy new.
loggyboy
| posted on 11/9/12 at 07:29 PM |
Waterproof connector - 3 pin UK SELLER | eBay
Mistral Motorsport
baz-R
| posted on 11/9/12 at 07:37 PM |
and buy new.
ah i know where thay can be found http://www.polevolt.co.uk/acatalog/info_4564.html
rick1962uk
| posted on 25/9/12 at 08:50 PM |
i use these guys a lot http://kojaycat.co.uk/ they are great quality and can supply almost any OEM conctor
umgrybab
| posted on 29/11/12 at 11:03 AM |
I always use waterproof connectors because they always work, forever. If money was no object I would only use Deutch connectors, available here:
http://www.polevolt.co.uk/acatalog/Deutsch_DTM_connectors.html
But because I need that money to spread out over other car parts I buy Delphi Weatherpack connectors, available here:
http://www.diyautotune.com/catalog/weather-pack-kits-small-connector-kits-c-74_73.html
| posted on 29/11/12 at 03:06 PM |
Snap
+2
Excellent service every time I used them.
umgrybab
| posted on 29/11/12 at 04:45 PM |
Snap
+2
Just had a look at the cost, WOW those are expensive. If you're looking to save money, go Weatherpack.
