baz-R
| posted on 30/9/12 at 02:17 PM |
aftermarket fuel pressure reg's?
hi im looking for fuel pressure reg (around the 3bar) and idealy ajustable
there seems to be all sorts of good bad and ugly stuff out there
i just want to know what works ok is not too expensive and is safe
and your experinces
idealy i want hose tail fittings and want 1:1 ratio with a vac point
will121
| posted on 30/9/12 at 03:13 PM |
I would avoid the cheap ebay ones, the one I had wouldn't hold a pressure half way through being mapped, ended up with i think a fse one, do you
need a adjustable one? as wonder if a 3 bar fixed OE might be less hassle
T66
| posted on 30/9/12 at 03:25 PM |
I think the last time this thread came up, the Webcon one was suggested as a decent fpr, have a search to confirm.
http://www.webcon.co.uk/Downloads/WFR505%20Oct%2008.pdf
baz-R
| posted on 30/9/12 at 04:03 PM |
i cant find one with tails over 2.7 bar i dont mind findint somthing that can take some form of std hyd fitting
baz-R
| posted on 30/9/12 at 04:36 PM |
i have seen a few webcon ones the fixed type are basicly a oem reg in a holder thay have designed and made and the ajustable one is the same with a
ajustable reg in
not what i would call cheap or good value but probably work fine
webcaon regs
paulf
| posted on 20/10/12 at 08:57 PM |
As far as I could tell they use the Bosch cartridge as used by fords etc mounted in the fuel rail.I got a ford reg capsule and turned up a housing for
it and have had no problems, there are a number of different ratings available as they are used on many different cars.
Paul
daniel mason
| posted on 20/10/12 at 09:45 PM |
i have a really nice, sx performance fpr. take a look at photos in my archive and my busa build diary
coyoteboy
| posted on 22/10/12 at 11:00 PM |
I bought a ~90 "quality" aftermarket one from a reputable online source (I actually genuinely can't remember who, it was about 2
years ago) and had it hooked up to a ~200 pressure sensor and a datalogger for a while. It was horrendously poor at generating repeatable pressure
from one run to the next, like +- 1.5 psi poor.
God knows what the cheap ones are like but I suspect they'd struggle to be much worse
[Edited on 22/10/12 by coyoteboy]
