hobbsy
posted on 13/11/12 at 06:22 PM |
Powercommander 3 USB Yamaha R1 Wiring Loom Help - need pinout
Hi all,
I have a PC3 USB which I'd like to fit to my R1 Fury (I currently have a PC3R fitted).
The wiring loom is toast (it was removed from a R1 that went up in a fireball at Mallory).
However if I apply 12V it appears to light up ok.
On the PC3 USB I have about a foot of cable that is good - the original 4 and 6 way connectors were cut off.
I have removed the 4 way and 6 way plug and sockets from a spare loom - so if I can solder these on to the chopped off loom it should be back in
business.
UPDATE Now got the info I need from Dynojet! So I don't need anything else (other than what I can look up in the Yamaha wiring diagrams). I
will leave it up here for anyone else who needs this info.
PC3 USB wires:
Red - +12V
Black - GND
White w/ yellow tracer – Injector #2 signal output
White w/ blue tracer - Injector #4 signal output
White w/ orange tracer - Injector #1 signal output
White w/ green tracer - Injector #3 signal output
Black w/ white tracer – digital ground (TPS ground reference)
Grey – TPS analog signal input (0-5 v input)
Green - Injector #3 signal input
Yellow - Injector #2 signal input
Orange - Injector #1 signal input
Blue - Injector #4 signal input
[Edited on 13/11/12 by hobbsy]
