garybee
| posted on 19/11/12 at 08:50 PM |
Zetec 2L cams, Escort inlet/injector plate
A few things for sale, more to be added.
Set of camshafts from a 2L silvertop zetec in good condition. Good upgrade for your 1.8L silvertop. £30 + postage
Escort injector sandwich plate. This is the section which houses the fuel injectors, can be used for making your own custom plenum setup. I also
have the rest of the inlet manifold, if anyone is interested in it for some reason. Offers invited.
Steel flange to mount to above sandwich plate. Again, to manufacture your own custom plenum. Can also be used to make an 8 injector setup using bike
throttle bodies and the above injector sandwich plate. £20 + postage
Pictures will be added later.
ChrisW
| posted on 20/11/12 at 10:09 AM |
Which manifold is it? Does it have the 'SO' or 'HO' stamp on the back of runner 4? Does the sandwich plate
'match' the inlet ie it came off the same car? (the port sizes should match when put together)
Chris
My gaff my rules
garybee
| posted on 20/11/12 at 10:45 AM |
The sandwich plate and inlet manifold are both from the same car and are 'SO' type. There is plenty of meat on there for if you want to
make the inlets larger too.
