Author: Subject: Gen 2 coil pack HT connectors
flak monkey
posted on 22/11/12 at 07:38 PM Reply With Quote
Anyone know of a source of HT lead connectors to fit the 2nd gen Ford coil packs? Can find loads of places selling the early clip on type.
Need to make a set of leads up for my Camaro, and just need those connectors. They are M4 connector like a spark plug without the screw on cap, but buried deep in a tower. Sure if I could find some M4 push on lead ends I can use normal coil rubber seals....
TIA
mcerd1
posted on 23/11/12 at 09:56 AM Reply With Quote
not sure, but wouldn't it be easier to use the gen 1 coilpacks ?
(that way you'd be able to get leads easily if you need another set)
otherwise you could get a long set of std. leads and cut the plug ends off....
[Edited on 23/11/2012 by mcerd1]
flak monkey
posted on 23/11/12 at 11:23 AM Reply With Quote
Yeah, looks like I'll do that, it was just I had acquired some of the second gen coils already, thought they used std coil connectors. But there we go!
Called the breakers and they have some gen 1 coils, so will get some today
mcerd1
posted on 23/11/12 at 01:06 PM Reply With Quote
at least the breakers don't normally want much for them
I've got a spare one here, but the postage would be more than its worth!
