thurso
posted on 16/12/12 at 05:43 PM |
zzr1400 sump mods
hi has anyone done a diy sump mod by cutting, extending welding sump? any photos info
thanks
INDY BIRD
posted on 16/12/12 at 05:58 PM |
Mmm prob wouldn't go there I would fit a billet sump from an performance as we did and had no issues on track,
When I bough the mnr with the zx14 it had a modded sump but when I took it off to inspect it was not great and can see hwhy the engine seized up,
Just my opionion others will follow I'm sure?
Sean
wylliezx9r
posted on 16/12/12 at 06:38 PM |
Sean
I agree with an expensive lump like that I wouldn't take any chances.
George Best
paublo999
posted on 16/12/12 at 09:40 PM |
You've got time Lenny - look at importing from Schnitz or the likes.... Save some good money doing that
Edit: http://store.schnitzracing.com/adams-performance-low-profile-billet-oil-pan-kawasaki-zx14/
[Edited on 16/12/12 by paublo999]
My videos http://www.youtube.com/user/ninjabogeyracing
paublo999
posted on 17/12/12 at 01:00 PM |
But you'll also need a remote filter kit to use that sump
Johneturbo
posted on 17/12/12 at 01:20 PM |
AB performance does a billit sump
i got mine
fromHERE as a another member from USA locostbuilders recommended him
So far it's been running fine with good oil pressure
[Edited on 17/12/12 by Johneturbo]
thurso
posted on 17/12/12 at 08:07 PM |
zzr1400 sump mods
HI folks thanks for your comments
Paul I have the adaptor for the oil filter/cooler, plus inline filter housing .oil cooler, NB engine now in place and mounted
when I look at the billet sumps I still think that cutting existing sump and extending then adding baffle plate would more or less be the same as a
billet
did this on the ZX12 with no problems???
paublo999
posted on 17/12/12 at 08:30 PM |
Sounds like a plan. Big engine to starve of oil (like I did) but have heard of a few running fine with billet but not heard of any diy's but
this is locostbuilders. Just depends how much it will cost you to get it all welded up rather than £500 from the states.
With the engine in, how much does the sump sit below the chassis rail? Schnitz sell a chopped sump, you might get some ideas from it
thurso
posted on 18/12/12 at 12:59 PM |
zzr1400
Paul hi I would do all the welding and fabrication myself , ex fully coded welder you know!!!
engine sump pan the flat flange where the bolts are is about 15mm above the bottom rail
still not sure about welding the sump not for any other resaon that when you cut off the filterhousing there wont be any flat area in the location to
weld an extension on easily?
paublo999
posted on 18/12/12 at 02:10 PM |
Not sure if this helps - http://store.schnitzracing.com/schnitz-modified-low-profile-oil-pan-kawasaki-zx14-06-11/
Didnt know you were a welder, shame you live on the other end of the country!
