Valtra
posted on 9/1/13 at 12:27 AM |
Fuel filter with 12mm barbed fit
Has anybody found an OEM injection pump pre-filter with 12mm barb fittings ?
"If it looks like it works and it feels like it works, then it works"
cliftyhanger
posted on 9/1/13 at 06:38 AM |
YB cosworth stuff uses 12mm fuel hose, but the filters accept a screw in union.
I suspect otherwise it is a case of sytec and the other aftermarket ones, usually available off fleabay.
big-vee-twin
posted on 9/1/13 at 08:19 AM |
I got one off ebay it has screw-in fittings I used it as a reducer 12mm from tank 10mm to pump, the guy who sold it even put the fittings i needed on
it.
Here 12MM 15MM SYTEC MOTORSPORT BOSCH FUEL INJECTION PUMP PRE FILTER 044 COSWORTH HI#
Or here SYTEC FUEL FILTER FOR FORD ESCORT RS TURBO COSWORTH CAPRI SIERRA XR2i MLR.HH put your own fittings on.
[Edited on 9/1/13 by big-vee-twin]
http://www.triangleltd.com
Valtra
posted on 9/1/13 at 10:02 AM |
it.
Yes I'd found these but wondered if there was a cheaper oem alternative. The Freelander /mgf/elise filter looks fine but the m14 thread is not
easy to find 12mm barb adapters for
Valtra
posted on 14/1/13 at 12:57 AM |
ESR4065 XJS / XKR / Rand rover Disco 1 / fuel filter m16 x 1.5 ends, plus Brass 12mm Compressor hose tails to suit . £10.24 . Filter itself only
£3.59 so pretty cheap service item .
