Alfa145
| posted on 15/2/13 at 09:57 PM |
Fuel Return Pipe Diameter
I have an existing 6mm copper fuel pipe in my car and I'm in the process of upgrading to fuel injection and I will be fitting a new 8mm high
pressure pipe for the fuel feed and thinking of using this existing pipe as the return to tank.
Is 6mm a suitable diameter for using as a return for the new fuel injection set up?
Rob
daniel mason
| posted on 15/2/13 at 10:30 PM |
are you running an fpr at all?
Alfa145
| posted on 15/2/13 at 10:45 PM |
if FPR is Fuel Pressure Reg then Yes. Just after the fuel rail.
| posted on 16/2/13 at 09:32 AM |
6mm is fine for a return line.
daniel mason
| posted on 16/2/13 at 09:47 AM |
6mm will be fine. thats what im using!
scudderfish
| posted on 16/2/13 at 10:14 AM |
If you're overloading a 6mm pipe on fuel return, you need to use the loud pedal more!
| posted on 16/2/13 at 11:13 AM |
I used a 10mm pipe as return to stop it interfering with the pressure regulator.
coyoteboy
| posted on 17/2/13 at 10:17 PM |
Same diameter as your FPR feed pipe would be suitable.
