ragindave
posted on 14/3/13 at 03:46 PM |
Fuel Injectors
Some advice needed please as I have fairly limited knowledge on Fuel Injection.
These are Bosch Injectors 365cc would they fit/work with Jenvey throttle bodies?
Would they have enough flow for a standard 2.0 Zetec blacktop.
Bosch Injectors 0280155868
ali f27
posted on 14/3/13 at 04:43 PM |
HI those injectors will run 212 bhp at 80% and 252 at 90% duty cycle so a bit big for standard zetec
Goggle Stan Wiess injector flow chart
matt_gsxr
posted on 14/3/13 at 05:10 PM |
They will certainly flow enough. Really a bit too large, but if you reduce the squirts per cycle then you will probably be fine.
Worst comes to the worst you might get a slightly eratic idle. If you already have them then give them a go, if you are going to buy them then look
elsewhere.
Matt
ragindave
posted on 14/3/13 at 05:29 PM |
Thank you very much.
zetec
posted on 15/3/13 at 08:49 AM |
Agree they are a little big for anything up to 200BHP, I've got something like 220ish fitted and work perfect. Also the body looks different to
those I use, I'd check with Jenvey.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
BaileyPerformance
posted on 15/3/13 at 10:18 AM |
Will fit the jenveys OK but those injectors are designed for a 2 valve per cylinder engine and so have a narrow spray pattern, and are too big for a
stock 2.0L.
Just go to the scrapyard and get a set of focus 2.0L zetec injectors (white) this are 200cc/min.
ragindave
posted on 15/3/13 at 05:30 PM |
Thanks I am glad I asked now very helpful indeed lots to consider!
