Author: Subject: Do I need intake air temp for megasquirt controlling spark
dave_424
posted on 26/3/13 at 08:24 PM Reply With Quote
I'm heading home from uni for a week and a bit and want to start wiring my megasquirt into my engine. I have throttle bodies but don't have the fuel pump or FPR yet, so I would like to try and run spark on my engine with carbs installed.
I have coolant sensor, and TPS on the carbs.
Can I get spark working on my engine without an intake air temperature sensor? using alpha-N from my TPS for my engine load.
Would just like to make some noise and have a sense of accomplishment for the week.
Dave
SPYDER
posted on 26/3/13 at 08:59 PM Reply With Quote
There should be no problem. I've been running spark only and without an air temp sensor for years on my 3SGE MS1 V3 install.
dave_424
posted on 26/3/13 at 09:02 PM Reply With Quote
As I thought, the main sensor needed other than the TPS is engine coolant sensor which I have so timing can be changed to warm up the engine.
Dave
