Valtra
posted on 2/5/13 at 07:19 AM |
serial cable
Quick one
I'm assuming it's ok to leave the serial cable attached to the ecu on a Micro/megasquirt? whilst it's in use but not connected to a
laptop ?
cheers
Ian
"If it looks like it works and it feels like it works, then it works"
scudderfish
| posted on 2/5/13 at 08:35 AM |
Yes, just tuck it away somewhere and try to avoid letting anything metallic touch the pins. Probably no more of a risk than just having the regular
port on the MS uncovered.
Valtra
| posted on 2/5/13 at 11:24 AM |
Thanks. Much appreciated
coyoteboy
| posted on 2/5/13 at 05:48 PM |
I never leave mine attached, you effectively have a large antenna on the end of your pins (depending on how good the shielding is on the cable you
have). Unlikely to cause a problem but it's possible.
Valtra
| posted on 2/5/13 at 09:08 PM |
Also useful , I'll perhaps disconnect once the car's running well
