theprisioner
posted on 18/7/13 at 06:08 PM |
Puma ECU advice urgent
I have a 1.7 Sigma engine in my kit (1997 Ford Puma 1.7 VVT). It has it's original ECU from the Donor car and it works fine. I have had the
engine mechanicals upgraded to Racing Puma spec and want to remap the ECU accordingly and get 20BHP almost free.
Unfortunately I have an early ECU called Dude and according to Pumaspeed they do not have the ability to remap that particular version.
In frustration I have purchased a 2000 year ECU from ebay see item: 111105045827.
I have the following urgent questions.
1) Is their any differences that matter in the wiring loom
2) I assume the key information is hard coded into the ECU therefore I have to change the lock?
3) How do you remove the old barrel?
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
monkeyarms
posted on 18/7/13 at 06:21 PM |
1 - check the ford TIS for specific pin outs
2 - yes
3 - put key in, turn to pos1 then press the small indent on the lock barrel, it should push down and barrel pops out.
Just to check, can that new ECU take the FRP map? I know only certain ones can, but i dont know which.
[Edited on 18/7/13 by monkeyarms]
beaver34
posted on 18/7/13 at 06:42 PM |
what ecu have you got iirc you need a TAPE ecu to be able to map it, there are other companies other that pumaspeed that can do it.
have you got the inlet and the cams then also?
theprisioner
posted on 18/7/13 at 06:44 PM |
The original was DUDE I am told they can remap a DIVE ECU that I have bought!
What does FRP mean, excuse my ignorance?
[Edited on 18/7/13 by theprisioner]
Chris_vrs
posted on 18/7/13 at 06:47 PM |
FORD RACING PUMA. N. Z I had loads of these cars. Easy peasy to map. I even turbod mine. I can upload a picture of my pistons after the remap if
you want !
www.gardencitylocksmiths.co.uk
Chris_vrs
posted on 18/7/13 at 06:48 PM |
FRP IS JUST Ford Racing Puma
beaver34
posted on 18/7/13 at 06:49 PM |
ford racing puma
id rather set fire to myself than give pumaspeed money thats all
puma931
posted on 18/7/13 at 06:50 PM |
contact Alan @ www.Pumabuild.co.uk he knows loads about the FRP (he looked after my FRP no 17).
[Edited on 18/7/13 by puma931]
beaver34
posted on 18/7/13 at 07:36 PM |
Can run a tape (ph1) ecu on a dive (ph2) loom ok, just change the white temp gauge wire from pin 80 to pin 75
theprisioner
posted on 18/7/13 at 08:04 PM |
The original loom is DUDE and the new ECU is DIVE, excuse my ignorance but what is Tape(1)(2)?
My loom has nothing on 75 or 80
ste
posted on 19/7/13 at 04:27 AM |
TAPE & DIVE are the ECU codes. IIRC the TAPE is single lambda DIVE is twin
FRP map can be loaded to TAPE and MUFF but most people prefer TAPE
My friend breaks pumas so if you need anything specific I can ask him
