r1_pete
posted on 14/9/13 at 07:51 PM |
A Good day in the garage.....
Started with this
stock manifold
Cut it down some, and then some more
Version 2, first tentative cut
Made some of these
runner
Welded it altogether
Manifold2
Manifold1
Next stage is injectors and fuel rail.
Plan was to build an efi manifold and buy the TIG set to do it for less than the £1475 for a Mangoletsi setup, and I;m still way under £1000 including
the R Tech 160 TIG.
[Edited on 14/9/13 by r1_pete]
jacko
posted on 14/9/13 at 07:58 PM |
Nice work keep the photos coming
Jacko
jossey
posted on 14/9/13 at 08:16 PM |
Good work.
David Johnson
T66
posted on 14/9/13 at 08:46 PM |
Tidy work, a good day !
BaileyPerformance
posted on 15/9/13 at 09:41 AM |
Did you consider using the standard SU inlet with Jenvey SU to throttle body conversion plate? Then 3 standard single Jenvey throttle bodies with and
injector in each?
We have a 1968 3.8 e type in the workshop at the mo, mangoletsi SU inlets with his new twin cable linkage and peddle box. (The car is left hand
drive)
The man himself turned up to take some measurements from it, bit of a surprise to meet a legend.
We are retaining the SUs, just fitting megajolt, will be interesting to see what power it produces.
40inches
posted on 15/9/13 at 10:46 AM |
That's excellent work Pete, nice to see the Triumph throttle bodies worked out. Have you sorted the fuel rail?
r1_pete
posted on 15/9/13 at 01:09 PM |
injector in each?
I don't have a tri SU manifold, I'm running twin SUs and Megajolt at the moment, I did think about two single point SU injectors, but
liked the idea of the injectors in the standard Jag (XJ6) position. Plus its cost me less than £100 in parts to get this far.
It was the Mangoletsi Direct to head injection setup I was fancying, very neat and tidy but a tad pricey....
Mangoletsi
Fuel rail is the next job, I've got a couple of D shaped extrusions, I'm a bit apprehensive about drilling them though, I'm using
Subaru injectors so might try and get a cheap Subaru rail to measure so I'm sure the hole dia is correct.
[Edited on 15/9/13 by r1_pete]
40inches
posted on 15/9/13 at 01:29 PM |
Are Subaru injectors different from the Bosch injectors? I have a Jaguar steel fuel rail that may fit, you are welcome to try it.
r1_pete
posted on 15/9/13 at 01:36 PM |
They are different Dave, I think I need an 11mm drilling in the rail for the injector O ring, but I'm not 100% sure yet.
40inches
posted on 15/9/13 at 01:48 PM |
The Jag rail is 13.3 dia and the injector "O" ring 14.7, they don't mean them to leak, do they?
BaileyPerformance
posted on 15/9/13 at 07:50 PM |
injector in each?
Mangoletsi
Humm... My mistake, a had assumed all e types had the 3 SU setup, we are looking at an injection setup for the 2 SU setup using the Jenvey TBs, we
will be using an air box and MAF as we find a MAF to be the best and most accurate regarding fuelling.
As for the e type in the workshop at the mo we are sticking with the SUs, to be honest the fuelling is not too bad, 14afr light throttle, bit rich
(12afr) full throttle but I think that's due to the poor air box setup. The car made 195bhp and 250lbft with the stock dizzy and points.
We'll see what megajolt does for it.
As for your injectors a set from a 325 BMW would be spot on i think.
r1_pete
posted on 15/9/13 at 08:18 PM |
I got the car with triple 45 DCOEs, the SUs are on a US spec Twin Stromberg manifold modded to remove the secondary chamber.
All UK E Types had tri carbs, it was the US emission regs which gave rise to the Strombergs for their market.
I've got a bag full of 420cc Subaru / Denso injectors I'm planning on using, fuel rail is next weekend's job, unless its fit to get
the car out to make room to put the bonnet back together for the 4th time.....
I have never RR'd the car but the Megajolt made a noticeable difference.
Cheers.
Pete
