Author: Subject: Data logging from a standalone wideband
mark chandler
posted on 27/11/13 at 06:31 PM Reply With Quote
Hello
My DB7 has a Zytec ECU, this poses a problem as not OB2 compliant and to extract any data you need bespoke MSDOS software and a dongle.... Not a lot of chance getting that
I want to datalog the AFR, so am looking to buy a simple wideband, these all tend to have an analogue output but I really need to capture rpm, TPS Map and AFR.
So does anyone know of anything that I can plug various voltage based inputs into, then push to a smartphone, blue tooth would be favourite or maybe has a serial or USB output that I could use with a laptop.
Thanks Mark
gremlin1234
posted on 27/11/13 at 08:59 PM Reply With Quote
one way is to use the 'sound card' input, (with some buffering of course)
else raspberry pi may be the way to go
http://en.wikipedia.org/wiki/Raspberry_Pi
coyoteboy
posted on 28/11/13 at 10:21 PM Reply With Quote
Sounds card would need some mods, they have capacitive decoupling from DC.
Don't think the Pi has any ADCs on it so you'd need an add-on card and some code. Might as well write a specific logger with a PIC for that much effort Or hook up a megasquirt as a piggyback as I did when I first bought it, to characterise the stock ECU.
[Edited on 28/11/13 by coyoteboy]
