GRRR
posted on 13/3/14 at 09:05 AM |
Dimensions of Zetec SE/Sigma and gearbox?
Hey all,
Just wondering if anyone has dimensions of the Puma/Fiesta engine and gearbox assembly? I'm trying to sort out the positions of my inboard
wishbone pivot points and they're pretty much dictated by which bits if engine are in the way.
Cheers!
monkeyarms
posted on 13/3/14 at 09:30 AM |
As luck would have it, I have a puma engine in my garage. What dimensions would you like, over all sizes?
![](http://locostbuilders.co.uk/upload/2lump.jpg)
GRRR
posted on 13/3/14 at 09:38 AM |
This is why LCB is the best website on the internet. Thanks!
yeah overall 'space envelope' dims like eng and box total width and depth, height of engine from lowest point whether gearbox or sump,but
also if possible the distance from the driveshaft output centre line to the front of the eng and box assembly, if that makes sense (ie if you looked
at the car from the side, how far is it from the middle of a wheel to the front most part of the engine).
Thanks again
Nick
monkeyarms
posted on 13/3/14 at 09:44 AM |
ok i will get the tape measure out when i get home and let you know tonight.
monkeyarms
posted on 13/3/14 at 06:37 PM |
Right, the length of the engine and gearbox is 900mm
the height is 620mm
the width is 650mm
If i have understood you correctly, the distance from driveshaft CL to exhaust side is 150mm and other way towards inlet is 500mm (150+500=
650width)
Obviously allow a bit extra onto my dimensions.
Hope this helps, let me know if you need any more.
GRRR
posted on 13/3/14 at 10:25 PM |
Fantastic, that's awesome, thanks so much for doing that ![](/images//smilies/smile.gif)
