Author: Subject: Testing a Tacho
AntonUK
posted on 6/5/14 at 09:36 PM Reply With Quote
Testing a Tacho
Does anyone have a method or circuit diagram to allow the testing of a Tacho on the bench i.e. without an engine?
I've found a few 555 based circuits but all are 5v outputs
Build Photos Here
theprisioner
posted on 7/5/14 at 10:15 AM Reply With Quote
555 Timers will work up to 16V
see:https://www.fairchildsemi.com/ds/LM/LM555.pdf
It would be a very good way of checking it out.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
SPYDER
posted on 7/5/14 at 01:52 PM Reply With Quote
I recently calibrated an old tacho using the 12v output from an old battery charger. I tapped the transformer output before the rectifier. The 50hz signal equated to 1500 revs. The tacho was a Cortina Mk2 item which senses pulses in the 12v coil feed wire. The technique may not work for a modern unit. Might be harmful even. But it might work??
AntonUK
posted on 7/5/14 at 06:00 PM Reply With Quote
Technically that would shove a sine wave to it... might work tho...
I have a 555 timer circuit to try later, if that fails i'll attack the battery charger.
Build Photos Here
