Irony
posted on 7/7/14 at 04:27 PM |
Megajolt Map RV8 3.9 Weber 500 required.
Does anyone have a known good megajolt map for the above to get me started.
BaileyPerformance
posted on 9/7/14 at 10:28 AM |
HI,
I don't have a map, but use the following to create your own...
The megajolt has throttle position or MAP on the vertical axis, RPM on the horizontal axis. just to get you going you don't need to worry about
3D mapping, just 2D.
1000RPM = 10
1500RPM = 16
2000RPM = 20
2500RPM = 24
3000RPM =28
3500PRM =32
4000-6500RPM = 34
This will be fine to get you running, an will drive fine assuming your carb is setup correctly.
We can setup the carb and megasjolt for £250 on the rolling road.
www.baileyperformance.co.uk
