blakep82
| posted on 20/9/14 at 12:41 PM |
respacing itb throttle linkage help!
Hopefully someone might have an idea on how to extend this? Its a bit too close to be easy, but too far apart to be reliable as is
It'll need some sort of thing made to fit in the space I expect, but I can't think what it needs to look like, any ideas/drawing? Even
better if someone on here can make it too
________________________
HowardB
| posted on 20/9/14 at 01:01 PM |
how about 2 triangle shaped washers, drilled and wire locked to the tab,... maybe even fold the end of one over to create the same spacing between the
springs,...
sketch could be forthcoming if required,.....
hth
Howard
cliftyhanger
| posted on 20/9/14 at 03:13 PM |
Looks like the bracket bit that the adjuster is on is steel? Could cut and weld to correct spacing, or remake the bracket?
blakep82
| posted on 20/9/14 at 03:20 PM |
All aluminium I think?
Thank you for the suggestions, however as is always the way, you ask for help and end up finding an answer yourself!
I realised I could remove a spacer washer (1.6mm?) And the spacing was still good, and the pin sits right in the middle of the fork. I think its all
good!
