richardh
posted on 7/11/14 at 09:43 PM |
Car tries to stall when accelerator is pressed
hi, I have a problem I can't solve - again! Lol
Was driving ok earlier today but then starts doing this:
Standing still revving past 2500 it dies right down and stalls unless I back off the revs
If I drive then the same happens and I can't get passed 3rd gear even downhill.
Idles fine
I can barely get uphill and have to be in 1st and under about 1200 revs.
It's fuelled to 1/4 of a tank with fresh fuel.
The filter is on the pickup in the tank from what I can tell.
Plugs all seem a good colour and correct gap.
Nothing changed from last times it worked although I did have a starting issue a while back but I put in £20 of fuel earlier.
Wondering if the CAT is maybe breaking down?
It's a Sportrak.
Time for a change!
pekwah1
posted on 7/11/14 at 10:02 PM |
is this the kit car? what engine?
had a very similar problem recently and turned out to be a dodgy o2 sensor....
richardh
posted on 7/11/14 at 10:19 PM |
Daihatsu sportrak 1.6 efi
Can't even find the sensor - mind you not had a decent light at hand to try
Time for a change!
mark chandler
posted on 7/11/14 at 11:24 PM |
If the cat is melting down you will get very little induction draw, the gases have nowhere to go so it stops being able to suck in fresh air.
richardh
posted on 7/11/14 at 11:42 PM |
Would that give the symptoms described?
Time for a change!
mark chandler
posted on 8/11/14 at 08:10 AM |
Yes it will, it's unlikely the cat will block completely, as it melts into a blob the symptoms get worse, this happens quite quickly as well.
posted on 8/11/14 at 08:51 AM |
It sounds like a fueling issue, clogged fuel line, duff fuel pump, but first check the MAP, TPS, CTS and any other sensorsxare not disconnected.
DW100
posted on 8/11/14 at 09:07 AM |
Is it since you played with the fuel pump, tank, gauge sender and fuel lines?
Has it run properly since?
gremlin1234
posted on 8/11/14 at 07:11 PM |
'though it might not help, I suggest disconnect the battery, and charge it overnight. ie let all the electrics reset
(aka turn it off and on again, with a freshly charged battery)
richardh
posted on 8/11/14 at 10:32 PM |
Hi, it's run fine since the fuel tank and gauge thing. Done about 100 miles since then.
I think it's the cat broken down and was going to remove it temporarily to test the running without it.
I'll blow the fuel lines through and see what there is there.
I had a similar problem many years ago with my daily minded 24v and it was cat related.
Time for a change!
