posted on 3/12/14 at 09:26 AM |
OBD Android app better than Torque!
Couple of months back I downloaded Obd Car Doctor Pro and I have found it a improvement over Torque mainly because the graphing of live data is much
better which is useful for checking O2 sensors.
[Edited on 3/12/14 by britishtrident]
mookaloid
posted on 3/12/14 at 11:20 AM |
Downloaded - will give it a try.
big_wasa
posted on 3/12/14 at 11:49 AM |
Thanks I will have a look.
loggyboy
posted on 3/12/14 at 11:52 AM |
Been using that a while now, clears codes well, better than the £15 all in one reader I was using.
Mistral Motorsport
owelly
posted on 3/12/14 at 04:18 PM |
I have an OBDKEY but it doesn't like my Espace OBD! It's a 2004 derv and the dongle is 'unable to connect to ECU'. Will all
dongles be the same? It works OK on my 2002 A4 petrol and 1999 Saab derv to a certain extent. It also worked on my 2002 and 2005 derv Range Rovers and
has worked on quite a few other supposedly non-complient vehicles including the Pug V6 I've fitted to my kit.
http://www.ppcmag.co.uk
posted on 3/12/14 at 05:12 PM |
Oil burners were only required to be OBD II compliant from 2005 two years later than petrols.
owelly
posted on 3/12/14 at 05:27 PM |
Yup. That I know, but most of the dervs I've tried work to a certain extent, as early as 1999. I used the OBDKEY on a 2004 Laguna with limited
functions working but the Espace won't play ball at all.
