Mj2326
posted on 11/5/15 at 04:07 PM |
What fuel pump/pressure
Hi I'm currently building a westfield bringing it into the modern world.
My question is what fuel pressure/pump do I need to be running for a 1.8 zetec with gsxr 600 throttle bodies controlled with the megasquirt ecu. I
understand I will require a fuel regulator too. The original is a 3 bar pump but from what I've read ill need higher pressure?
Please can someone point me in the right direction
Mike
dave_424
posted on 11/5/15 at 07:07 PM |
3bar is the standard fuel pressure for injection.
Mj2326
posted on 12/5/15 at 06:44 AM |
So ill be fine with 3 bar with the throttle bodies or do I need to uprate the pump?
adithorp
posted on 12/5/15 at 07:41 AM |
Do the TBs have a fuel return line? Most TBs but not all do. If they have then it'll incorporate a regulator and you'll be fine with 3bar
pump. If not then the original pump would have had pressure reg' and you'll need to fit one.
http://jpsc.org.uk/forum/
theduck
posted on 12/5/15 at 08:20 AM |
As far as I inow, uprated Efi pumps are designed to increase flow without increasing pressure.
Mj2326
posted on 12/5/15 at 09:24 AM |
Yea it's just a single fuel line so need to fit regulator to feed back to tank someone told me Ill be fine with a single feed to the fuel rail
as long as I have a regulator fitted in the circuit feeding back to the tank. Was gonna go for the fse sytec air004 is this the correct 1 for my needs
