Author: Subject: Another TPS Question
r1_pete
posted on 12/9/15 at 08:59 AM Reply With Quote
I bought a cheapo Ford TPS, I don't think it was much more than a fiver so probably not much good, but, it enabled me to mod the throttle body to take a tps, and not risk damaging an expensive one.
Question is, should it be spring return, or do they rely on a really good fit on the shaft to return to the idle position?
Its the common Ford type:
TPS
TPS
posted on 12/9/15 at 09:37 AM Reply With Quote
No internal spring, exactly the same in operation ad the volume control on an old style TV or Radio.
40inches
posted on 12/9/15 at 09:52 AM Reply With Quote
Some Ford TPS's have a spring return, there are also left and right rotational Ford TPS. The spring
return type use a blade rather than a D shaft.
I have an anti clockwise sprung TPS if that helps, I also have the Duratec throttle body that came with it But it is
only 58mm bore.
r1_pete
posted on 12/9/15 at 09:56 AM Reply With Quote
Cheers guys, I'd better be careful filing the flats on the shaft then.
Yeah, 58mm bore would be a bit small Dave....
40inches
posted on 12/9/15 at 10:05 AM Reply With Quote
You are welcome to the TPS and the throttle body for reference.
Duratec TPS
[Edited on 12-9-15 by 40inches]
