40inches
posted on 20/9/15 at 12:11 PM |
FPR vac connection
Is it necessary? What are the advantages to connecting it?
CosKev3
posted on 20/9/15 at 12:24 PM |
Alters the pressure according to the vacuum applied iirc?
Rising rate fpr.
coyoteboy
posted on 20/9/15 at 02:08 PM |
It's for boosted engines, so you can maintain relative fuel pressure, or for engines where you can use a varying fuel pressure to effectively
increase the resolution of control of fueling
40inches
posted on 20/9/15 at 02:25 PM |
So reduces fuel pressure, say at tick over, to maintain a steady idle speed, rather than relying on altering injector duty cycle?
Not had to assemble a fuel injection system before, so a bit of a Dumbo, but learning fast
coyoteboy
posted on 20/9/15 at 02:37 PM |
Yeah, so they can be set up to either stretch the useful range by increasing pressure with load, or drop it around idle to give more control.
I've never set one up (on an engine, I used it in a very strange lab experiment) but you can see they give some flexibility. If you want to just
get a system running you don't //need// to connect the hose.
40inches
posted on 20/9/15 at 02:41 PM |
Got it A case of if it's there, why not use it.
posted on 21/9/15 at 06:42 AM |
There are some good videos on YouTube on the operation and testing of fuel pressure regulators, the - `Schrödingers box` channel or `ScannerDaner`
channel are good places to look.
