Author: Subject: Stationary(ish) airflow with ford MAF meter - problem for supercharging?
Chaz
posted on 8/12/15 at 07:38 PM Reply With Quote
I'm in the process of supercharging my silvertop Zetec.
Will I have problems of 'stationary' airflow on an MAF sensor, which I think is the 'hot wire' type?
How far back from the inlet valves will it need to go to avoid sluggish throttle response?
1800 Zetec, eaton M45 s/c, 130ps cams
Thank you
old_timbo
posted on 8/12/15 at 09:39 PM Reply With Quote
What ECU are you using? Do you need a MAF? On my Supercharged / Megasquirt Pinto I used IAT + MAP (Speed / Density)
Chaz
posted on 8/12/15 at 10:35 PM Reply With Quote
I'll be using megasquirt, an injector per runner.
The pipework will be (from the inlet valves back to air filter) valves --> runners --> plenum --> intercooler --> supercharger --> throttle body --> air filter
Somewhere in there I need an airflow sensor of some sort right?
What are other people doing?
jeffw
posted on 9/12/15 at 06:16 AM Reply With Quote
You don't need a MAF. Use the Throttle Position Sensor and a MAP sensor.
Ben_Copeland
posted on 9/12/15 at 06:30 AM Reply With Quote
^ what they said ....
Ben
Locost Map on Google Maps
Enter Your Details Here
Chaz
posted on 9/12/15 at 07:12 AM Reply With Quote
Oh ok, I was going to use MAP and TPS anyway. So I don't need MAF as well?
jeffw
posted on 9/12/15 at 02:27 PM Reply With Quote
no
