Plunky
posted on 21/5/16 at 12:12 PM |
Fuel pump
I have recently been doing a lot of work on my F27, attempting to get the new blacktop Zetec running right.
I have noticed that lately the fuel pump seems to be really screaming, and looking at the gauge its pushing nearly 5 bar!
What could be causing this? Is it a sign the pump is on its way out?
Thanks,
Liam
HowardB
posted on 21/5/16 at 12:46 PM |
Injection pumps can deliver more than 10 bar. The system pressure is controlled by the regulator. Is it an adjustable type?
Howard
Plunky
posted on 21/5/16 at 01:03 PM |
I don't think it's adjustable...
HowardB
posted on 21/5/16 at 01:11 PM |
Most systems are 3bar.. I would suggest something is a miss
Howard
40inches
posted on 21/5/16 at 01:58 PM |
What make of pump and regulator? Photos?
gremlin1234
posted on 21/5/16 at 09:32 PM |
pumps running full bore can be down to the pressure relief 'circuit' flowing straight back to the tank, and may need some
'restriction' to lower the flow. the pump will slow as its output pressure is higher.
Plunky
posted on 23/5/16 at 07:07 AM |
I'll get some pictures today...
It's almost as if there is a blockage somewhere and the pump is trying harder and harder to pump fuel.
Will pull the lines today and see if I find anything
HowardB
posted on 23/5/16 at 07:45 AM |
I tested my line by blowing air through them, I also checked the regulator the same way,. 3 bar is 45psi so easy with a bike pump
Howard
Plunky
posted on 24/5/16 at 09:18 AM |
I had a play around with the regulator today, looks like the adjuster was loose... Hopefully sorted now
