Author: Subject: Book states 1" for wishbone anchors
VinceGledhill
posted on 22/12/16 at 09:03 PM Reply With Quote
Hi People.
The book states 1" for the wishbone anchors, (the round tube on the wishbones themselves, where they anchor to the body)
But I've found these on ebay Haynes Roadster Locost Front Wishbone Bushes in Poly - 10% OFF for my atom replica build.... the diameter of "that bit" being 29mm
I'm looking to purchase my steel for this part of the build, and can't decide what I need. Any help would be appreciated.
[Edited on 22/12/16 by VinceGledhill]
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
chris_smith
posted on 22/12/16 at 09:25 PM Reply With Quote
i used these off the bay, and they will fit perfect the bushes you have seen
Haynes Roadster FULL SET of 22 Wishbone Bush Tubes 33.7mm dia x 35mm long.
ste
posted on 22/12/16 at 09:26 PM Reply With Quote
My book states 33.7mm for the bush tubes.
Slimy38
posted on 22/12/16 at 09:28 PM Reply With Quote
The 1 inch tube is for the wishbones themselves, not the 'anchors'. The tube required for the bushes is the 33.7mm seamless. It's a bit awkward to find but is a standard size, I got about 1.5m for all the wishbones.
Talon Motorsport
posted on 22/12/16 at 10:05 PM Reply With Quote
If you end up using 33.7x3mm welded tube make sure the seam faces the open end of the 25mm 'leg' when you weld it.
VinceGledhill
posted on 22/12/16 at 10:17 PM Reply With Quote
Nice one Chris. That's saved me a job cutting them all. Ordered.
My book definitely says 1"
Regards
Vince Gledhill
907
posted on 22/12/16 at 10:36 PM Reply With Quote
I machined mine from 1", but that's 1" nominal bore SCH 80 machined out to 25mm bore.
Thats the stuff that you would thread 1" BSP
[Edited on 22/12/16 by 907]
snapper
posted on 23/12/16 at 07:02 AM Reply With Quote
The one and only member of the Suttol Owners Club
Do you have to own a Suttol to be a member or can I be an Associate member if I have parts on my car made by a Suttol owners club member?
I eat to survive
I drink to forget
Slimy38
posted on 23/12/16 at 08:20 AM Reply With Quote
Note that they're not seamless, so take into account what Talon mentioned about burying the seam inside the weld.
907
posted on 23/12/16 at 09:42 AM Reply With Quote
Mmmmm, dodgy one that. I've never associated with anyone before.
You could of course make me the sort of offer that I couldn't refuse.
hughpinder
posted on 23/12/16 at 03:55 PM Reply With Quote
What??????????
You want to wake up with a horses head in your bed.....
Or I suppose the equivalent - your car engine full of sand and leaking oil everywhere
