chris
posted on 27/2/17 at 05:02 PM |
megasquirt ms3
hi i am just converting to fuel injection with a ms3 megasquirt but i cant find any info as to wether i need to fit separate ignition coil suppressors
to the coil on plug coils in the instructions it said to fit one to a coil pack but nothing about cop,s any info would be gratefully received
SPYDER
posted on 27/2/17 at 07:18 PM |
I run Hayabusa COPs on my car running from an MS2 fitted with four spark outputs. I have a noise suppression cap and a ferrite on the common 12V
supply but no other caps. Works fine.
theduck
posted on 27/2/17 at 08:12 PM |
I dont think they are needed for logic level coils on MS3.
Also, which manual are you using? Best off using the ones on http://www.msextra.com/ which also has a really good forum.
chris
posted on 27/2/17 at 08:31 PM |
Hi Stuart I am using the efi extra wiring diagram
[Edited on 27/2/17 by chris]
dave_424
posted on 27/2/17 at 09:53 PM |
Not needed, I didn't use one when I used a ford coil pack with an MS2 using BIP373 high current driver.
Also not using one on Lexus 1UZ-FE ignitors
You'll be fine
chris
posted on 27/2/17 at 10:26 PM |
Ok thanks will try without
