Westfield XTR
Westfield XTR2 Sprint / Hillclimb car THIS CAR HAS NO V5C
Part of a car collection on of stored for many years. Is not for the faint hearted!
Full specifications
Chassis supplied by Westfield in April 2007
MSA logbooked.
2006 Hayabusa 1300, dry sumped, HD clutch plates and springs, fitted with a Power Commander
Westfield front brake upgrade, vented discs with 4pot calipers.
Solid discs and calipers on the rear with inbuilt handbrake
Nitron shock absorbers.
Stack gauges.
Digital gear indicator.
6 point 3in race harness on driver's seat and 4 point 3in harness side.
2.5 kg plumbed in extinguisher.
Compomotive CX race wheels 8x13 front and 8.5x13 rear with Avon ZZ-S
Spare Set of CX 7 X13” with Michelin Pilot Sports slicks 20/54
Foam filled fuel tank in N/S side pod.
Twin plane rear wing with carbon end plates – XTR4
All emission gear removed and a non "cat" exhaust
Flat Shaft Paddle system with flat shift. (Partly installed)
Recent freshen up in the Aerodynamics work shop. Currently the engine is out for new HD gearbox shaft
New long wheel studs and wheel nuts
New front lightweight alloy hubs and bearings run out checked
Brake fluid flushed
New Plugs
Oil Change
FIA rain light
Large race mirrors
Fasteners replaced with stainless steel
Looking for, £16500 but open to sensible offers Photos and information on request. Neil 01738 550005
