Author: Subject: Ford MAF Pinout Help..
r1_pete
posted on 11/8/19 at 11:40 AM Reply With Quote
Hopefully the last call for help with this stock ecu setup, think I have the ecu pinouts sorted, last hurdle is the MAF, as it didn't have a connector with it.
I need to know which pin is which, I think they are
Signal
Signal Ground
+12v switched
Ground.
Pins are marked A B C D E, only A C D E used, can anyone help with which is which?
Cosworth MAF 1
Cosworth MAF 1
Cosworth MAF 2
Cosworth MAF 2
[Edited on 11/8/19 by r1_pete]
40inches
posted on 11/8/19 at 12:09 PM Reply With Quote
This any help Pete? http://www.msextra.com/doc/pdf/html/MS2V357_Hardware-3.4.pdf/MS2V357_Hardware-3.4.html
Section 3.4.7
r1_pete
posted on 11/8/19 at 12:16 PM Reply With Quote
Cheers Dave,
Just found the info on a Finnish site, hopefully google translated it ok....
E - Signal
D - Signal Return
C - Ground
A - Switched 12v
big_wasa
posted on 11/8/19 at 05:04 PM Reply With Quote
r1_pete
posted on 11/8/19 at 06:30 PM Reply With Quote
Cheers Warren,
The brown blue wire in position D is the same colour as on my diagram...
Its a pity the manufacturers don’t stick to a standard like the old Lucas colours...
