shaywez
posted on 31/1/05 at 08:31 PM |
test
Well i finally got around to sending off my SVA application today, then i rang the test centre in Exeter and the person i spoke with was really
helpfull. Test should be ok for Feb 28th so i suppose i should pull my finger out now and sort the finishing touches eh!! Any advice anybody on the
nitty gritty, much appreciated![](/images//smilies/smile.gif)
flak monkey
posted on 31/1/05 at 08:33 PM |
Take that bit of string off holding yer exhaust on in your avatar
Sera
http://www.motosera.com
posted on 31/1/05 at 08:50 PM |
And cover your boot
and fit a bonnet. Good luck. Put us a couple of pictures of the finished article in your archive.
[Edited on 31/1/05 by Peteff]
posted on 31/1/05 at 09:03 PM |
the obvious fails are sharp edges. youy need to really go over the top on these - and it needs to look perminant, not lagging and tie-wraps.
then visability in the mirrors,viewing angles on lights etc.
super important, is get the name of the tester and make sure that he does you retest (theres no shame in failing, most do) cos if its a different
tester they might fail you on something else! which would be VERY annoying.
posted on 31/1/05 at 09:45 PM |
It's also REALLY worth taking some time to make the car look good - nice, clean and shiny. Tart it up nicely, as the tester's first
impressions count a lot.
Show him a smart car and he won't give it half as much attention as a scruffy, shabby piece of work - or he'll be a bit more forgiving,
anyway.
Don't worry - it's not as bad as you think it's going to be!
Good luck,
P.S. I put a brief SVA page on my website - follow the link below and look through the menus.
Bananaman
posted on 1/2/05 at 08:50 AM |
From my experience at Exeter last year the 2 testers are really good. They will give you time at the end of the test to fix any minor issues. They do
not get upset either when you question their decisions. They will go out of their way to help. Mine had a leaky main seal and they only ran the engine
the bear minimum. Take plenty of edging material. Also make sure that your wiring terminals are the insulated type.
Good luck.
Michael
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
barrie sharp
posted on 1/2/05 at 03:43 PM |
I Will second what banaman says we had our test at the same time .they are very helpful before the test if you ring them with a problem.
my advice is dont be late my tester told me that was his pet hate when they turn up just in time and then spend 20 mins unloading from trailers
etc..
They do like all wires well supported and cable tied up and not rubbing on other things so take care!
Take all your documents to regester your car because the dvla place is just around the corner, how easy is that!!
Good luck with it
Barrie
![](/images//smilies/wink.gif)
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
Lightning
posted on 1/2/05 at 04:39 PM |
Byron is the guy at Exeter and he is very enthusiastic about kits. He will pass it if he can. If you have any problems phone him up and he will put
you right, He likes to see that people have made the effort. If it fails (like mine did) he will undoubtedly tell you exactly what you need do.
Mine failed on not having a collapsible boss. Indicators too far in, and emmisions.
His favorate fails are no symbol on the Brake indicator light on the dash ie: (O)
and not supporting the fuel filter.
Keep your rear mirrors high to see over the rear wheel arches.
I actually enjoyed the day ....so don't worry!
shaywez
posted on 1/2/05 at 08:13 PM |
test
Thanks for all the advice so far gents as it is all good stuff and much appreciated, cheers![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif)
Snuggs
posted on 1/2/05 at 08:46 PM |
ford calipers
Hi
If you are using Ford calipers and banjo type connectors then you must ensure that the surface arund the hole is machined flat. Also you may need to
prove to the tester that the hole is not tapered. A good photo should be OK
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
shaywez
posted on 2/2/05 at 07:19 AM |
cat
I dont require a cat as the engine was manufactured before Aug 1995
